Create a layer from a table and a layer using a Join
2171
09-15-2022 01:58 PM
lmotta_ibama
Hi guys,
I would like create  a layer, from a table , where the geometry field (Shape) come from a layer using a Join.
My table have a key, where can use with a layer with same field (key).
The 'Add Join' tool, get all field from layer, but, not add the geometry.
Have a tool in ArcGIS Pro for add the geometry in a table, to create a layer ?
Or
I can use a SQL and the result i define how a layer ?
I have a lot of tables, and I need the geometries from a only layer.
A SQL can be this:
SELECT t.id_city, t.name_seller, t.total, l.Shape
FROM cities_salles t
INNER JOIN cities l ON t.id_city = l.id
RhettZufelt
MVP Notable Contributor
Where is your geometry?  In a table, feature class?
Basically, make/copy your feature class with the geometries, then use Join Field to add table to that copy of the feature class.
R_
lmotta_ibama
Thanks RhettZufelt ,
I have a layer (feature class), that i would like use yours geometries to others tables.
All tables have a key, that join with the key of layer.
The "Join field" tool, add only attributes from the foreign table.  This case, it add all attributes of all tables. The result a layer with a lot of attributes.
I would like use the geometries from the only a layer for all tables, then, I can work with each table with geometries from the same layer.
The idea is have a "Join Geometry" tool, then, we can do a Join from the fields (table and layer), that the geometries of layer will be add in table, promoting a table to layer.
