Clipping/Splitting a Line across Multiple Polygons
5276
06-16-2021 01:02 PM
Labels (2)
DanaThompson1
Can somebody help? Let's say I have a line that goes across a United States polygon layer. Is there a tool that can clip/split the line whenever it crosses a state boundary? Ex. If a line goes from Colorado through Utah, Nevada, and California-- the result would be 4 segments.
The Split "modify features" tool is too manual as I have thousands of lines to edit and the Clip tool only works if I'm going inside and outside of a polygon.  Am I missing something?
Thanks.
DanLee
by Esri Regular Contributor
DanLee
Use Intersect tool to intersect your lines with the States polygons.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/analysis/intersect.htm
DanaThompson1
I knew it was something simple! Thanks, I forgot about that.
