Clip Raster (Data Management)—ArcGIS Pro Large AGOL Raster
1529
05-10-2022 05:32 AM
TylerT
I need a small area of this raster https://opendata.dc.gov/datasets/DCGIS::aerial-photography-orthophoto-2021/about
What is the best practice to clip a small portion of this raster, ouput smaller raster to PC, and keep it's georeferenced info.  Ultimately I need to use it further in ArcGIS Pro, and use it in AutoCAD, so will need a wld file or embedded georeferenced data.
My attempt failed.  I added the raster to my map through the catalog and AGOL Portal then used Clip Raster (Data Management) to perform a clip.  It did not behave as expected.  I expected a single tif output, however, after several hours, 90GB, many miscellaneous folders and miscellaneous files I stopped the operation.
Thanks for your help.
Tyler
RhettZufelt
MVP Notable Contributor
The output format of the clipped raster is determined by the extension of the output filename.
If you name it filename.tif, will create a tif file.
I prefer to create a polygon of the area that I want to clip, use that as my output extent, and select use input features for clipping geometry.
R_
TylerT
Yeah, I had named it properly.  The tool was still creating bunches of folders and files.  Maybe it was downloading the entire aerial first?  I'lll try again with a clipping polygon.
Tyler
RhettZufelt
I read folders and files and figured that sounds like the GRID format.
Maybe those are temp files since 90+Gb sounds pretty big for "a small area".
Did you
R_
