Check to see what user (or if no user) is logged into Pro
332
05-10-2024 05:46 AM
TL2
try:
    gis = GIS("Pro")
except:
     logger.error()
I would like to get notified (except) when Pro fails to log in because no user is currently logged in or return the user that is logged in.
Tags (3)
DavidSolari
if not arcpy.GetSigninToken():
    fail()
portal = arcgis.GIS("Pro")
EdMorris
Hi
I'm not sure if you found a solution to your original post? If not then you you might find the following code snippet useful:
from arcgis.gis import GIS
try:
    myGIS = GIS(url = 'pro')
    print(myGIS.users.me)   # This will display the
                            # user who accessed ArcGIS Pro and is used to
                            # then authenticate the connection to your portal
except ValueError as e:     # if nobody has authenticated using ArcGIS
                            # Pro then a ValueError is generated.....
    print("There was an error\n")
    print(f"The error is:\n\t{e}")
Hopefully this will do the trick and identify who has authenticated using ArcGIS Pro and a suitable error message displayed if nobody has authenticated.
If you have already authenticated using ArcGIS Pro; then run the above code and THEN sign out of ArcGIS Pro and re-run the code again, then the myGIS.users.me returns a None object. You might want to code for that outcome...?
I hope this helps you out - Let me know how you get on?
many thanks
ed
