Changing the Z values of a feature vertices according to the vertices of anthor feature
523
06-26-2024 10:53 PM
AyaAbbas
Hello,
I have a polygon Z feature with many vertices and anthor feature of point Z type, Is there's any method using ArcPro to  replace the Z values of the polygon vertices by the vertices of the point feature automatically?
Bud
Esteemed Contributor
You could submit an idea: https://community.esri.com/t5/arcgis-pro-ideas/idb-p/arcgis-pro-ideas
If you do submit an idea, it would help if you could link to it here so that I can follow it.
Bud
Can you describe the relationship between the points and the polygon vertices?
  1. Do the point features have a common ID with the polygons?
  2. Does the location of the points exactly coincide with the polygon vertices?
  3. Is there a point for each and every polygon vertex?
  4. Can you show us a screenshot of the features and any ID attributes in the attribute table?
  5. What is the geodatabase type and spatial data type? For example, Oracle enterprise geodatabase, SDE.ST_GEOMETRY.
