Change database connection for all layers
11815
7
06-17-2015 02:23 AM
DavidVent
Hello,
how is it in ArcGis Pro possible to change the database connection datasource for all Layers.
Thank your for you help.
Experience: With ArcCatalog it was possible to change mxd files datasouce of layers.
MichaelRobb
Honored Contributor
ArcGIS Server question?
You can only do the Change data Source for multiple IF the links are broken.  Depending on the situation, one would/could update broken links layer by layer. Update all broken links in Dataframe at once. But what if there are No broken links but want to change the source?
David does not state 'broken layers' anywhere...but rather 'how to change the database conneciton datasource in all layers'
I use py to re-source all layers with the following example:
*caveat: the new datasource must include all the FeatureClasses etc used in the original
Import arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
mxd.findAndReplaceWorkspacePaths(r"Database Connections\xxxxx.sde",r"Database Connections\xxxx.sde")
QuinnFrancis
Hi David,
You can change the data source of layers by right clicking on the layer in the Contents pane > Properties > Source tab > Change data source.
Repair broken data links—ArcGIS Pro | ArcGIS for Professionals
MichaelRobb
Honored Contributor
Import arcpy
MarcelSt-Germain
Yes, one layer by one layer.  For now it's in planing phase for change datasource.
Esri doesn't understand this need so no rush on this.
In the waiting time, i'm doing this by creating a broken link (putting a x before the name of the database) after the project is closed.  Then, I repair multiple link with these instructions.
Réparer des liaisons de données endommagées—ArcGIS Pro | Documentation
Hope this will be of some help.
MikeMillerGIS
Esri Frequent Contributor
Not sure if this will work in you situation, but I sometimes export the map to a mapx, open in notepad++ and use find and replace. Mapx is a json file
MarcelSt-Germain
But, just changing the source in pro by creating a broken link is simpler for me.  Maybe one day they will include link management.
MikeMillerGIS
2.6 has some good stuff coming.
MarcelSt-Germain
Yes, can't wait to see.  Date of release for 2.6 ?
