Cannot edit the attribute table in arcgis pro 1.4
4065
07-10-2017 12:45 AM
JohnaChemjong
Before adding some information on attribute table it was working but after sometime it is not working properly. What is the solution?
JayantaPoddar
Does the attribute table have a joined table/excel sheet which is also opened? Try closing all applications and try again. Reboot ArcGIS Pro, if needed.
Think Location
DanPatterson_Retired
What is the edit status of the file? Did you save, then stop edits at some point? go to the editor toolbar and 'start' editing that file? Does that work?
Try to include more information as to when it worked and when it stopped working.  What did you do during the intervening time period.
shan_sarkar
Johna,
When you try to edit the attributes does it throw any errors? If so can you share that?
~Shan
~Shan
AlbertGarcia4
I had this problem as well - I had forgotten that I compressed the geodatabase, uncompressing it solved the problem. Not sure if that's the case here but worth giving a look.
Good luck!
-Albert
