I have point data stacked on street intersections. They are colored in one of 5 different colors. I was able to extrude the points based on frequency, but the entire column is colored the color of the top point. I would like to have the column show all 4 colors of the different points that make up the stack. Is there a way to do this? See attached picture below. You can see that some of the other colors are showing through. It would be ideal if I could organize them by priority too. So black is on top, then red, then blue, etc and users could quickly gauge not only the frequency but type based on color.
Solved! Go to Solution.
Hi Tom,
I've heard this question a couple of times. The short answer (I believe) is no.
The points are placed based on their location and Z value. In order to get the "stacked" and extruded look I believe you are referencing:
This is a post on a different thread about ArcScene, but as you'll see from Xander where he is taking a similar approach by stacking on top of one another. https://community.esri.com/thread/70656
An example would be:
Point 1: Begins at 0, extruded to 15 feet
Point 2: Begins at 15 feet, extruded to 30 feet
Point 3: Begins at 30 feet, extruded to 50 feet
And so on ..
Hopefully this helps in some way !
Best,
Kiersten
Hi Tom,
And so on ..
Best,
Kiersten
