Can you make multi colored 3D columns?
1644
07-22-2019 10:23 AM
TomMagdaleno
I have point data stacked on street intersections.  They are colored in one of 5 different colors.  I was able to extrude the points based on frequency, but the entire column is colored the color of the top point.  I would like to have the column show all 4 colors of the different points that make up the stack.  Is there a way to do this?  See attached picture below.  You can see that some of the other colors are showing through.  It would be ideal if I could organize them by priority too.  So black is on top, then red, then blue, etc and users could quickly gauge not only the frequency but type based on color.
KierstenHudson
Hi Tom,
I've heard this question a couple of times. The short answer (I believe) is no.
The points are placed based on their location and Z value. In order to get the "stacked" and extruded look I believe you are referencing:
  • Start your first point at the ground level and extrude to the height value desired (could be based on an attribute in your data)
  • The next point (zvalue) should START at the same height in which the previous was extruded to, and the extrusion value would be an attribute value in the data.
    • You can set an expression in the appearance tab to follow the above extrusion structure
This is a post on a different thread about ArcScene, but as you'll see from Xander where he is taking a similar approach by stacking on top of one another. https://community.esri.com/thread/70656
An example would be:
Point 1: Begins at 0, extruded to 15 feet
Point 2: Begins at 15 feet, extruded to 30 feet
Point 3: Begins at 30 feet, extruded to 50 feet
And so on ..
Hopefully this helps in some way !
Best,
Kiersten
KierstenHudson
Hi Tom,
And so on ..
Best,
Kiersten
