Can't select multiple features in map
9252
13
10-04-2021 12:03 PM
Labels (2)
JoeBorgione
Using ArcGIS Pro 2.7.4, I cannot interactively select multiple features in a map.  When I hold the shift key down with the select tool selected it zooms in.  Is there a hot key setting I need to turn off?
In my gif below, I select one street segment, clear the selection and then select the adjacent segment and clear. Then with the first segment selected, I hold down shift and when I try to select the second segment, it zooms in.ShiftNoWorkee.gif
Lake_Country_GIS
Fixed for me as well - after the 3.2 update.
Matt-Goodman
This is currently happening to me (again) with ArcGIS Pro 3.0.
AngelBarnett
This is still an issue for me in 3.0.3
AngelBarnett
UPDATE: I run into this issue EVERY time I use the Address Locator tool.
After using Address Locator, the Select tool switches to zoom when holding shift instead of allowing selection of multiple features. The only workaround I've found is to click the Explore tool then click back on the Select Tool.
Other ArcGIS Pro users in my office are experiencing the same issue. This has been a major inconvenience during projects involving mass edits to road centerlines and address points in which we are constantly using the Address Locator tool.
Is anyone else having this issue or is it a known bug?
Currently running latest version: 3.2.0
