Can't create more than two control points when georeferencing a DWG.
5294
7
02-16-2022 01:59 PM
Gustavo_Souza
I want to georeference a DWG file to make it a feature class.
However, whenever I start adding controls points, the option becomes unavailable after I add 2 controls points. But, 3 is the minimum necessary to have acceptable accuracy.
My reference is just the regular esri basemaps.
This is what happens as soon I add a control point.
lbraceromarre
Hello Gustavo:
I never done that in ArcGIS Pro with vector data. But I will suggest the following: (1)  first  convert DWG into a FC.Conversion CAD To Geodatabase
Afterwards, (2) define and then use (3) Project tool,  to project the dataset in desired projection.
Define Projection Tool
Project Tool
Maybe it doesn't allow you add points because it already has some geographic information?
Or, if you are working in the software DWG file was created, assigned the projection from there. It should work when you inserted the file into GIS.
Cheers.
GregoireCatineau
Finnaly it's normal, because we don't need more than 2 controls points for a vector layer.
VijayShinde
I'm also getting the same issue,
Is there any solution for this
esrisupportsiggis
I'm experiencing the same problem. After adding 2 control points, I click a vertex in the dwg to add a 3rd. At this point the Add Control Points button becomes greyed-out, and the only thing I can do is to Apply the 2 control points. After this the Control Point Table is cleared. Very strange behaviour, as imo it should be possible to transform the dwg by adding multiple control points to correctly georeference it.
Couldn't find much info in ArcGIS Pro documentation. Any new information would be much appreciated!
TD1
I am having this issue as well
JakeNeedle
Any solution to this?  I am experiencing on version 3.7.
TD1
@JakeNeedle Still an issue for me. My workaround was converting the CAD file into feature classes using the CAD to Geodatabase tool. Once in this format, you will be able to add additional control points. Not ideal.
You can georeference a feature class but process a little bit different since it is not through the georeferencing tool.
Georeferencing a feature class is through the Modify Features pane and using the Transform tool Transform features—ArcGIS Pro | Documentation
Very annoying and I don't like the process.
