Can Layout/Activate Be Persistent When Exporting To PDF
2244
6
05-20-2022 01:29 PM
GRmapper
Hello,
I have been working with layouts and appreciate the value of the Activate button on the Layout ribbon. What I can't figure out is how to keep the Activated view all the way through to exporting particularly when I'm exporting a Map Series with multiple maps. Is this possible?
Thank You.
GR
AubriOtis
Ah ok, I understand now. You are trying to tweak the extent through activation and have that preserved in export. That's not possible with the user interface, although I believe you can accomplish that workflow using Python. Activation is supported in map series as a convenience to allow editing and exploring it isn't designed to change the extent which is driven by the map series itself.
Cheers,
Aubri
AubriOtis
I'm not sure what you are looking for here. Can you explain the result you are trying to get? Why does the map frame need to be activated during export?
Cheers,
Aubri
GRmapper
Sometimes I just really appreciate the control I have in that window. I just wish it could hold to export. If I have a part of a feature in the eastern hemisphere and it’s other part in the Western Hemisphere, moving the map in Activate makes it continuous. It might be my data.
AubriOtis
Cheers,
Aubri
DavidMc_Laughlin
Hi Aubri,
Have you got details of the python workaround for this?
Unfortunately, I'm coming across the same problem as @GRmapper  and need to use the activation to get the desired map location for the PDF output.
David.
AubriOtis
I'm not a python expert, but I've found I can accomplish a lot if I start with one of these samples and then tweak it for my scenario. Maybe one can help you? https://www.arcgis.com/home/group.html?sortField=modified&sortOrder=desc&id=398a345905c845e38229c15f...
Cheers,
Aubri
Sofia_Koroxenidou
Hello,
I know you found a solution using Python, but I just wanted to share what I do. I enable the Map Series, but if a map needs tweaking, I make the adjustments, then go to Layout, disable the Map Series, and export the layout without any problems. My adjustments—like activating and changing the map extent or moving the map—are all exported correctly. The issues only occur when the Map Series is enabled. And of course, when I’m done, I simply re-enable the Map Series and everything is still there!
Cheers, Sofia
