Can I select Point features that are only connected to 3+ Lines?
2058
02-07-2024 03:44 PM
DaniellaRose
Hi team,
Is there a way i can do a select by location thing where I can only select the point features that have 3 or more line features connected to it??
TIA
GTueller
Hi Daniella,
I would do a spatial join of the points to the lines, which will give you a field called "Join_Count" that will tell you how many lines the point intersects with. Then you can just do a regular selection based on that attribute.
GTueller
Hi Daniella,
MErikReedAugusta
MVP Regular Contributor
A quick clarification or two for both @GTueller and @DaniellaRose, because I can't remember and don't have a chance to test right this second:
  1. Is the intent to find points that intersect with at least 3 line endpoints, or 3 lines anywhere along their length?
  2. Spatial Join: Intersect will return the latter.  Would any of the Match Options in Spatial Join return the former?  Possibly "Boundary Touches"?
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
