Can I create/design my fields in Excel and import them to ArcGIS Pro while creating feature classes?
20185
14
04-03-2021 04:07 AM
AlexKweya
First off, I’m aware that one can import tables or fields from other feature classes when creating fields for a new feature class. However, so far unless I have an exact schema from another feature class, I have to additionally go through the list I import from an Excel table to set certain parameters like Field Aliases and Data Types.
My intention is to have some sort of template in Excel whereby I will design all my fields and specify the Field Name, Alias, Data Type, “Nullable Status”, Number Format, Domains and other parameters; after which, when creating fields for feature classes, on importing the Excel table, I can have them automatically populate as per the “attributes” set in Excel without having to tweak say the Alias or “Nullable Status”.
Is that possible? It would really be a better and faster way to create fields without moving around in the Create Feature Class pane to populate/adjust fields and values
I’ll appreciate any insights.
Alex Kweya.
alex_friant
There is an extension offered by Esri, the "Topographic Production Tools" toolbox, which allows you to do such things: https://pro.arcgis.com/en/pro-app/latest/tool-reference/topographic-production/generate-geodatabase-...
TravisColeHC
This is an old topic, but thought it might help someone. At least in Pro 3.5, you can bring the Excel file into Pro. Then export it to a table and use that table for the template of fields. It is pretty straightforward and easy.
WayneRennick
but can you specify all the Data Type and Length of the new fields?
alex_friant
There is a built-in set of Geoprocessing Tools that do this in ArcGIS Pro:
  • Data Management Tools
    • Workspace
      • Generate Schema Report
      • Convert Schema Report
      • Import XML Workspace Document
Your workflow would be something like this:
  1. Design your Geodatabase "template" feature class (fields, settings, domains, sub-types, etc.)
  2. Run the Generate Schema Report -- choose export option to XLSX
    1. You can make little tweaks in that spreadsheet in Excel if you need to
  3. Run the Convert Schema Report -- choose export option to XML
  4. Run the Import XML Workspace Document -- you'll need a Geodatabase as your target to deploy the schema to
Done.
