Can I (ArcGIS PRO 1.3)create and save projects to the d: drive or preferably to network drives?
2085
04-10-2017 11:43 AM
RichardDeFer
I can't seem to save to anywhere but the C drive.  Why?
DanPatterson_Retired
You will have to elaborate on your situation.  I have standalone machines and I have no problem saving to whatever drive I want.  Mind you, I am the administrator and in full control of my environment.  It sounds like you are not
RichardDeFer
CLASSIFICATION: UNCLASSIFIED
Well, I've been using Arcmap and Microstation for over 10 years with no problems saving to where ever.
I just installed ArcGIS PRO 1.3 and it seems I can't save a new project anywhere except buried in the C: (where I never save anything...'cept "favorites"). I was able to import an mxd from a network location and I later saved as to a mapped drive.
Our "office network drive" is
mvr-netapp2\ED-S<file:///
mvr-netapp2\ED-S> and I map to it and the network mvr egis directory; not by mapping a drive letter to the directories.
Suggestions? Thanks.
Richard DeFer
Engineering Tech.
CEMVR-EC-TS (Survey Section)
(309) 794-5477
when you go to the Project pane (using the arrow in the top left of the screen) and select Options, what is the default folder (probably your c:\whatever) and what is available to you when you click on the navigate folder?  It should list provide a list of drives etc connected to your machine.  I am using 1.4.1 and I can't remember way back when I first installed it whether it asked for a default drive-folder connection, but you can change it for subsequent projects in that general project area
RichardDeFer
I finally mapped to a folder on each network location (manually entering the network path).  ArcGIS Pro 1.3 doesn't seem to "like" displaying "connected" network locations, but it does display the last accessed location so I can back out to the "root" directory.
Thanks for your suggestion.
