I can't seem to save to anywhere but the C drive. Why?
You will have to elaborate on your situation. I have standalone machines and I have no problem saving to whatever drive I want. Mind you, I am the administrator and in full control of my environment. It sounds like you are not
CLASSIFICATION: UNCLASSIFIED
Well, I've been using Arcmap and Microstation for over 10 years with no problems saving to where ever.
I just installed ArcGIS PRO 1.3 and it seems I can't save a new project anywhere except buried in the C: (where I never save anything...'cept "favorites"). I was able to import an mxd from a network location and I later saved as to a mapped drive.
Our "office network drive" is mvr-netapp2\ED-S<file:///mvr-netapp2\ED-S> and I map to it and the network mvr egis directory; not by mapping a drive letter to the directories.
Suggestions? Thanks.
Richard DeFer
Engineering Tech.
CEMVR-EC-TS (Survey Section)
(309) 794-5477
when you go to the Project pane (using the arrow in the top left of the screen) and select Options, what is the default folder (probably your c:\whatever) and what is available to you when you click on the navigate folder? It should list provide a list of drives etc connected to your machine. I am using 1.4.1 and I can't remember way back when I first installed it whether it asked for a default drive-folder connection, but you can change it for subsequent projects in that general project area
I finally mapped to a folder on each network location (manually entering the network path). ArcGIS Pro 1.3 doesn't seem to "like" displaying "connected" network locations, but it does display the last accessed location so I can back out to the "root" directory.
Thanks for your suggestion.
