Can GPU help to and Speed up the Creation of Tile cache
633
08-16-2022 08:36 PM
ManShingTSANG
We are facing the problem in generating of the Tile cache map.
As our server have GPU resource, but seems there is NO reference show the Tile cache creation can use GPU resource.
We are using  ArcGIS Enterprise, ArcGIS Pro
May I know anyone have idea ?
Tags (1)
KoryKramer
Esri Community Moderator
Did you look at parallel processing factor as mentioned in this post https://community.esri.com/t5/arcgis-pro-questions/can-i-increase-image-tile-creation-speed/td-p/571... ?
Are you using the Create Map Tile Package tool or another tool like Manage Tile Cache? Both indicate that Parallel Processing Factor is supported which could help: https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/manage-tile-cache.htm#GUID-F...
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/create-map-tile-package.htm#...
Try that, but if you'd like to see specific tools with additional GPU support, I would recommend posting that as an idea in the ArcGIS Pro Idea exchange.
ManShingTSANG
 KoryKramer Many thanks for your reply. I will try try later ^^.
