We are facing the problem in generating of the Tile cache map.
As our server have GPU resource, but seems there is NO reference show the Tile cache creation can use GPU resource.
We are using ArcGIS Enterprise, ArcGIS Pro
May I know anyone have idea ?
Did you look at parallel processing factor as mentioned in this post https://community.esri.com/t5/arcgis-pro-questions/can-i-increase-image-tile-creation-speed/td-p/571... ?
Are you using the Create Map Tile Package tool or another tool like Manage Tile Cache? Both indicate that Parallel Processing Factor is supported which could help: https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/manage-tile-cache.htm#GUID-F...
Try that, but if you'd like to see specific tools with additional GPU support, I would recommend posting that as an idea in the ArcGIS Pro Idea exchange.
KoryKramer Many thanks for your reply. I will try try later ^^.
