Calculate Field with Python
5787
8
03-24-2021 04:28 AM
KalSsin
uniqueList = []
def isDuplicate(inValue):
  if inValue in uniqueList:
    return 1
  else:
    uniqueList.append(inValue)
    return 0
Hi~~~Please refer to the illustration.
Above coding to output 0 1.
I'd like to output 1 1.
DavidPike
MVP Notable Contributor
I'd probably run a searchCursor to generate a list of unique values, then run the field calculator using that list of pregenerated unique values.
DavidPike
Which field are you calculating on? Also unsure of the logic of that code compared to your expected output - doesn't make sense to me.
Anyway, as the code is executed on a per-row basis with the function, unique_list would have to be set to a global.
uniqueList = []
  global uniqueList
    return 1
  else:
    return 0
KalSsin
DavidPike
Are you saying the top picture is what you want - that makes sense to me - rather than the bottom picture?
looking at the code, I don't see how you got those results in the bottom picture either.  Did you try the code I suggested?
KalSsin
I used your code.
The picture below is the printout I want. I used your code.
I'd like to express all duplicate names by 1.
KalSsin
DavidPike
KalSsin
Thank you for your reply.
JakeSkinner
Esri Esteemed Contributor
It may be easier to do this with a script rather than the Field Calculator.  Ex:
import arcpy
table = r"C:\TEMP\PYTHON\Test.gdb\XY"
nameDict = {}
with arcpy.da.SearchCursor(table, ["NAME"]) as cursor:
     for row in cursor:
         if row[0] not in nameDict.keys():
             nameDict[row[0]] = 0
         else:
             nameDict[row[0]] = 1
del cursor
with arcpy.da.UpdateCursor(table, ["NAME", "Field"]) as cursor:
     for row in cursor:
         row[1] = nameDict[row[0]]
         cursor.updateRow(row)
del cursor
Result:
