Calculate Field IF Statement
1530
10-18-2024 01:38 PM
Labels (2)
CameronKoehler
I apologize in advance, I am new to ArcGIS Pro.  Is there an IF statement that can be calculated that says if the Street Name field begins with "State Highway" then return "State Highway" in the Street Pre Type field?
Attached is a screenshot showing the two fields in the feature class.
KevininMN1
Here's a sample with a few notes in the attached screen shot.  Good luck. use of python for function with string comparisonuse of python for function with string comparison
ChristopherCounsell
MVP Frequent Contributor
Open the field calculator on the empty field (field1), set to Python.
In code block put your if statement in a function:
def check_value(field2):
    if "X" in field2:
        return "X"
    elif "Y" in field2:
        return "Y"
    else:
        return None
Then in the top box call your function and point it at the second field:
check_value(!Field2!)
RonaldHaug
MVP Alum
Hi Cameron!
Why yes there is.
I think this help page will supply you with what you need.
https://support.esri.com/en-us/knowledge-base/how-to-use-if-statements-in-calculator-field-in-arcgis...
Let us know how you did!
KevininMN1
