I am using ArcGIS Pro v3.0.3
I have encountered a bug with the model builder in ArcGIS Pro. I wonder if anyone else has experienced similar issues and if there are any solutions to this bug.
The bug is that the “Auto layout” option in model builder ribbon is automatically applied to my model when I open it in edit mode from the toolbox database.
This auto layout functionality messes up the positions of all the geoprocessing tools and nodes within the model.
This issue started to occur after I upgraded to windows 11 business with Azure and linked a external HDD, Specifically after i changed a setting in windows the setting was called "SMB 1.0/CIFS File Sharing Support" I have since reverted the setting back but the issue still persists
If anyone can help me with this bug that would be much appreciated.
Kind regards,
Daniel
Situation update,
I have done some more tests and I am confident the bug is a result of ArcGIS pro v3.0.3
The auto layout bug automatically rearranges the tools in a model when the model is opened. You see the rearrangement automatically happen but there is nothing you can do about it. While the rearrangement happens the loading bar is present. The rearrangement makes the overview to the layout tools unorganized and not understandable. The bug does not effect the functionality of the model.
I still don't know the exact conditions in which the bug will occur.
My ArcGIS Pro 3.5.4 has ruined the structure of a Model builder script I've been working on for two weeks. All my work to the garbage!!
Yup, I feel this too. I did not hit "Auto Layout" and Pro 3.5.5 still moved all of my model parts around. I now have lines going everywhere.
BUG-000180065
This is frustrating for the user and should be embarrassing for ESRI. It seems it isn't because the this bug and many others are still in 3.5.4
