Add to display from model builder does not work when I open the model
1261
08-09-2024 02:26 PM
LyonMNGIS
I am able to add the results of a ModelBuilder script to an ArcGIS Pro map when I open up the edit dialog box and run the script.  However, if I open the tool then the results are not added to the map.
Is there any reason why the results show up when I run the tool through the edit model dialog and not when I open the tool?
Thanks!
Robert_LeClair
Esri Esteemed Contributor
The output has to be a model parameter to be added to the display.  In the model, right click on the output feature class and select model parameter.  Save the model and rerun in the GP pane.
BenClark
This was driving me bonkers. Thanks, @Robert_LeClair.
