Basemaps are not rendering correctly in ArcGIS Pro.
2348
03-12-2024 03:04 PM
norcal916
Does anyone know what might cause basemaps in ArcGIS Pro not to render completely? Depending on how far I zoom in or out on my map, weird lines and triangles start to appear on the basemap. Below are two screenshot of what this looks like using two different basemaps.
Navigation basemap:
Steets basemap:
DanielFox1
Hi @norcal916
Do you have this issue with all basemaps or certain default basemaps?
Do you have the same issue with ArcGIS Online or Enterprise?
What version of ArcGIS Pro are you running?
Can you run the system requirements check for your version of ArcGIS Pro, this might help point to any components that don't meet the requirements.
ArcGIS Pro 3.2 system requirements
norcal916
Hello @DanielFox1
It only happens with certain default basemaps (Streets, Navigation, Community, Streets (Night), Topographic, Light gray base).
I'm running ArcGIS Pro version 2.3.0.
I use ArcGIS Pro using Azure Remote Desktop from my Dell Laptop. Below are the specs for each:
Dell Laptop Specs:
Processor: Intel(R) Core(TM) i5-8365U CPU @ 1.60GHz   1.90 GHz
Installed RAM: 8.00 GB (7.78 GB usable)
System Type: 64-bit operating system, x64-based processor
Windows Edition: Windows 10 Enterprise
Version 22H2
Azure Remote Desktop Specs:
Processor: Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz   2.59 GHz
Installed RAM: 112 GB
Windows Edition: Windows 10 Enterprise for Virtual Desktops
Version 22H2
Below are the results I got from running the system requirements check you provided for ArcGIS Pro 3.2. I'm not sure if it's the same requirements for the older 2.3 version I'm running.
DanielFox1
Hi @norcal916
I would certainly recommend upgrading to either the latest version of ArcGIS Pro or to the last versions of ArcGIS 2.9.11 to ensure that you will be supported and also to see if this issue occurs at a newer version.
If you want to run v3.x.x I would recommend fulfilling the requirements missing or that have not met the system checker. https://pro.arcgis.com/en/pro-app/latest/get-started/arcgis-pro-system-requirements.htm
Is this something that has always happened or has only recently started?
If it has only started have there been any upgrades to your environment that might cause issues similar to what you are reporting?
