Backup In Progress impeding work 2.9.2
23664
22
03-21-2022 04:07 PM
JonHoch
ArcPro has begun stalling while doing it's regular back up; I believe since I updated to 2.9.2.
The Help file mentions, "The backup process does not interrupt your work or slow down the performance of ArcGIS Pro", but I would beg to differ as I am reoccurringly in a stalled state of not being able to select layers and other functionality and get frustrated and look up and sure enough [Backup in progress].
The default was 5 minutes so I changed to 10minutes but it's still annoying that things pause every 10minutes to do a backup that isn't supposed to interrupt your work...
Anyone else with that issue?
Robert_LeClair
Esri Esteemed Contributor
@Geobunga - sorry you're experiencing this freezing issue as well.  You mention that it's intermittent and seems to be with larger and/or older projects.  Question for you - is the ArcGIS Pro project stored on a network drive or is it local?  One thing to test is to create an ArcGIS Pro project file (*.ppkx) and then extract that to a local drive.  Then test to see if the "backup in progress" latency returns or not.  Keep in mind this is a complete copy of the original project but everything is "current" with regards to release.
Geobunga
Hi Robert, thanks for the prompt response. Much of the time we have this problem the projects are stored on a network drive, however this particular project is saved on my PC's local C: drive including all the data. The computer was purpose-built  for photogrammetry and 3D modeling/analysis last November so hardware should not be a limiting factor (Samsung 990 Pro SSD,13th gen Core i9, Nvidia RTX 4090,128GB RAM). Given it is already on the local drive, is it still worth saving a copy to see if it fixes the issue?
I have done quite a bit of geoprocessing in this project over the last few months and there are quite a few large layers. Most are turned off in the open map frame and the project's aprx is only 499KB. The project was working fine until about a week ago when it suddenly started hanging up while the backup in progress message is showing, as well as when I manually save the project.
Robert_LeClair
You're welcome.  So it may be something of note - you mentioned you've done a lot of GP in the project.  Sometimes clearing the GP History helps with strange errors.  You can do this by going to the Analysis tab->Geoprocessing group and History.  This opens the History tab.  Select all GP tools run and delete them.  Then test the backup in progress again.  Does it still hang?
