Attribute Rule Updating Two Intersecting Polygons
4197
13
12-06-2024 06:49 AM
PaulMAlexander
I am trying to create an attribute rule that when I update a field in one polygon, the intersecting polygon's field will also update.  Is there an an arcade expression I should try?
PaulMAlexander
Now how difficult would it be to change the expression if I am wanting it update multiple layers when changing the parent status and not just the building layer?
ZachBodenner
MVP Regular Contributor
Since that push targets a specific layer, what I would do is just create another rule, copy-paste the rule text, and then make the necessary adjustments (layer name, attributes changed, etc).
Happy mapping,
- Zach
PaulMAlexander
Great that really helped. Have you ever gotten an error messaged after implementing the rule that says "index passed was not within the valid range." ?
ZachBodenner
I haven't myself, but perhaps this thread can help you:
https://community.esri.com/t5/mapping-questions/the-index-passed/td-p/557777
Happy mapping,
- Zach
