Are there any 4-band backbone models for the Train Deep Learning Model tool or is there a way to use my own backbone?
768
06-21-2024 05:53 AM
Ruari_Langland
Just wondering if anyone has any knowledge of doing deep learning on 4-band imagery using the Arc Pro built in tools?
Additionally wondered if anyone had any luck applying a "bring your own model" approach to setting the Backbone Model in the tool. There are some great models on huggingface I would like to try, and they may need modification to accept a 4th channel:
https://huggingface.co/timm
Thanks in advance!
Ruari
PavanYadav
Hi @Ruari_Langland  and @Ed_
You can find some examples at https://developers.arcgis.com/python/latest/samples. This is one of them: https://developers.arcgis.com/python/latest/samples/landcover-classification-using-hyperspectral-ima...
The following is from a project I did sometime ago.. this one is 4-bands: i used RESNET34 .. the results were good
Here are my training parameters
max_epochs = 25
model_type = "UNET"
batch_size=8
arcpy.ia.TrainDeepLearningModel(in_folder=[TrainingSampleForLandcoverClassification],out_folder=Model_LandcoverClassification, max_epochs=max_epochs, model_type=model_type, batch_size=batch_size,arguments=[["chip_size", "224"], ["resize_to", ""], ["monitor", "valid_loss"]], backbone_model="RESNET34",validation_percentage=10, stop_training="STOP_TRAINING", freeze="FREEZE_MODEL")[0]
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
Ed_
by MVP Regular Contributor
@PavanYadav i have the same question, can you please share some resources on this? thank you!
Question | Analyze | Visualize
PavanYadav
max_epochs = 25
model_type = "UNET"
batch_size=8
Pavan Yadav
AI for Imagery
