ArcPro 3.0 Blend Modes in Layout View
2004
06-27-2022 10:09 AM
AmyDunn
I just updated to ArcPro 3.0 and opened a prior project with surface ownership polygons that were multiplying over NAIP imagery. I can still see this in map view, but when I switch to layout view I just get a blank box. I can only see my data if I turn the multiply off.
AubriOtis
That sounds like a bug. I recommend reaching out to technical support as they can troubleshoot the issue, generate a bug you can track, and get in contact with the right people to fix it. You can contact them here: https://support.esri.com/en/contact-tech-support
Cheers,
Aubri
compass_cartographic
Hello, I am currently having this issue in 3.0.2 and wondering if you ever found a solution, or did it turn out to be a documented bug?  Thank you!
AmyDunn
Yes, it's a bug. My boss and I had the same issue, he was working with ESRI support and they couldnt' figure it out.
HassanBasagic1
I am having the same issue after upgrading from 2.9 to 3.1. All my John Nelson inspired Screen blend modes no longer work in layout view, but look fine in map view.
