ArcPro 2.9.0 crashed using Select by Attribute
2618
6
12-16-2021 01:14 PM
Labels (3)
Hamg
Hi all,
Upgraded ArcPro 2.9.0 and its crashing when using Select by attribute process. I have tested it with different datasets but getting the same results.
Any recommendations would be helpful.
Thanks
Hussain
DanPatterson
MVP Esteemed Contributor
If it just crashes without any error, then you probably have a bad install.
Try  Add/Remove Programs (windows), Select "Remove" then "Repair".  A reinstall will be attempted.
Should that not work, then you will have to reinstall completely from the *.msi if you downloaded and saved the *exe and installed from it
... sort of retired...
Hamg
Thanks @DanPatterson , I will give it a try.
DanPatterson
Did you get this resolved?
Hamg
No, not yet. I am out of the office for Christmas, and I will update you once I am back in the office.
Thanks
H
Hamg
Hi @DanPatterson ,
Just wanted to update on you, I have installed the new copy of the ArcPro 2.9 and its still crashing on me. so I am going back to 2.8 for now.
Thanks
Hussain
DanPatterson
Tech Support would be best since there must be something fundamentally wrong since I don't see any error reports that are public
