ArcPro 2.7 Warning before upgrading (Failed to load system tools)
4384
12-17-2020 12:30 PM
EricPescatore
Just a healthy FYI out there to AGP users. Please be careful when upgrading using the in-app upgrade system to 2.7. Be sure to do it at the end of the work day. In my instance it broke my geoprocessing and python tools creating the "failed to create geoprocessing cache" and "failing to load system tools" error message. Trying to remediate may take hours you cannot afford that day.
ESRI does have a help document out there for these error messages.
https://support.esri.com/en/technical-article/000022262
Unfortunately in my case it will require me to uninstall and reinstall ArcPro. There are other solutions on the geonet to fixing this such as renaming Local/Roaming folders. But i would not recommend that unless your good at keeping your C: drive tidy.
DanPatterson
MVP Esteemed Contributor
@EricPescatore good warning.
My recommendation is to always do a clean install in the first place...
rename all esri folders in the "users" folders by appending "old" to the name is a good first step "before" reinstalling.
... sort of retired...
MarkZito
 asf
ScottSweet
Good advice.  Wish I would have seen this post before I updated.  Now AGP is constantly crashing and basic things like clip raster or build pyramids are not working.
GabrielMarcus1
I was excited to install 2.7 after watching the "what's new.." video. I already expected problems from the upgrade, so I waited until the daily work is done. After seeing Dan's advice on performing a clean install, I'm going to take Dan's advice.
ThomasL
I also had issues on a system and had to use this solution: Problem: ArcGIS Pro freezes on the initializing screen before the Sign In dialog box displays
Hope this help others upgrading ArcGIS Pro...
