Forest-based classification and regression predict to raster output empty
3546
12-20-2020 06:57 PM
PeterPorskamp
I am trying to use Forest-based classification and regression tool in ArcGIS Pro 2.4.3. My goal is to create a predicted surface using a training datatset (point feature) and explanatory training rasters. All my data is continous. The tool appears to run successfully but my output prediction surface is always empty.
Start Time: Monday, 21 December 2020 1:17:53 PM
Running script Forest...
Random Seed: 699645
Cell Size: 2.50
-------------- Model Characteristics --------------
Number of Trees 100
Leaf Size 5
Tree Depth Range 1-15
Mean Tree Depth 8
% of Training Available per Tree 100
Number of Randomly Sampled Variables 1
% of Training Data Excluded for Validation 10
------------ Model Out of Bag Errors ------------
Number of Trees 50 100
MSE 23.446 22.829
% of variation explained 45.088 46.531
----------------------- Top Variable Importance ------------------------
Variable Importance %
DISTANCE_TO_REEF_V3_CLIP_MASK_025 1871.38 29
ONLY_COASTAL_BC2_CLIP_MASK_025 1627.23 25
SST_RANGE_CLIP_MASK_025 1498.54 23
SST_MEAN_CLIP_MASK_025 1420.19 22
----- Training Data: Regression Diagnostics ------
R-Squared 0.705
p-value 0.000
Standard Error 0.029
*Predictions for the data used to train the model compared to the observed categories for those features
---- Validation Data: Regression Diagnostics -----
R-Squared 0.245
p-value 0.027
Standard Error 0.098
*Predictions for the test data (excluded from model training) compared to the observed values for those test features
--------------------------------------------- Explanatory Variable Range Diagnostics --------------------------------------------
Training Validation Prediction Training Validation Prediction
Variable Minimum Maximum Minimum Maximum Minimum Maximum Share(a) Share(b) Share(c)
SST_MEAN_CLIP_MASK_025 17.06 17.62 17.18 17.55 16.65 17.72 1.00 0.67* 1.91+
SST_RANGE_CLIP_MASK_025 6.60 6.86 6.66 6.84 6.27 7.16 1.00 0.70* 3.46+
ONLY_COASTAL_BC2_CLIP_MASK_025 1.00 3.00 1.00 3.00 1.00 3.68 1.00 1.00* 1.00+
DISTANCE_TO_REEF_V3_CLIP_MASK_025 0.00 2890.70 0.00 1355.60 0.00 3885.24 1.00 0.47* 1.34+
(a) % of overlap between the ranges of the training data and the input explanatory variable
(b) % of overlap between the ranges of the validation data and the training data
(c) % of overlap between the ranges of the training data and the prediction data
* Data ranges do not coincide. Training or validation is occurring with incomplete data.
+ Ranges of the training data and prediction data do not coincide and the tool is attempting to extrapolate.
Temporal File was not removed F:\02_ArcMap\Chpater_4\scratch\nc87172.flt
Completed script Forest-based Classification and Regression...
Succeeded at Monday, 21 December 2020 1:23:44 PM (Elapsed Time: 5 minutes 50 seconds)
DanPatterson
MVP Esteemed Contributor
what are the paths to your data?
is a bit concerning since depending on the type of raster you are producing, folders can't begin with a number.  Worth a check before you start digging too deep into the forest and check your file management
... sort of retired...
DanPatterson
PeterPorskamp
Thanks changing the location of my geodatabse fixed the issue.
