ArcGIS Pro takes 20 minutes to startup
13580
12
11-17-2021 08:20 AM
ArnieWaddell1
ArcGIS Pro takes 20 minutes to startup and can not figure out how to fix it.  Should I reinstall?
KikSiops
I have enabled the "Create a backup when the project has unsaved changes" option. I am accessing a data saved in a network drive, where can I find the backup for this one?
I am trying to troubleshoot latency issue when accessing files in a network drive in ArcGIS Pro.
LudvigPetersen
@ArnieWaddell1  I have similar issue. Could you be more specific with the Add-on - was it an ESRI add on or Windows Add on? Where did you find the Add on that slows the ArcGIS Pro?
JoshWhite
Honored Contributor
Are you saying you data was all changed to local too?  My project saves to local but it still takes several minutes to load some projects.  My data though is mostly ArcGIS Online Hosted feature services.  Editing is always slow to those hosted feature services too but that's another topic.
Josh White, AICP
Principal Planner
City of Arkansas City
