ArcGIS Pro not reading date field from Excel table?
1816
7
01-11-2024 06:34 PM
HayleyL
I have added an Excel table into Pro, with a series of date fields. In Excel they are formatted as dates to allow for Pro to read it as such. However once added to Pro it reads it as text, any pointers here?
I have tried reformatting to yyyymmdd and yyyy/mm/dd with no luck.
DanPatterson
MVP Esteemed Contributor
If the excel file has its columns formatted and there are no blank cells in a column, try
Excel To Table (Conversion)—ArcGIS Pro | Documentation
and see if the date information is retained properly
... sort of retired...
HayleyL
@DanPatterson didn't work either 😞
DanPatterson
Use date fields—ArcGIS Pro | Documentation
are the data in the same format as your computer's regional settings for dates?
MarkGilbert
I don't necessarily have an answer, but do either of these resources help?
Work with Microsoft Excel files in ArcGIS Pro  Specifically, take a look at the Limitations section, "...the field type specified in Excel is not used in determining the field type exposed in ArcGIS."
Date field in Excel to Table tool
Bud
Just a guess, but you could create a new field, set the format to date, then copy/paste the old field into the new field, but paste special (without formatting) so that the new field's formatting is honoured.
If that doesn't work, try using an Excel formula that outputs a date.
You could also attach a sample of the data to this forum post so that others can give it a shot.
Boyang_Wang
I am attaching a sample data, hoping that someone can help me to troubleshoot.
In excel, both date1 and date2 contain either Date value or General value (blank). When added to ArcGIS Pro, date1 becomes Text field while date2 becomes Date field. What is the problem with date1 column?
Thank you.
Bud
