ArcGIS Pro Model Builder Parameter Dependency Not Functional
117
Thursday
KristieReece
New Contributor III
I am attempting to create a simple model in ArcGIS Pro. The model has two variable parameters - one of which should dependent on the other. However, when editing the model properties the Dependency field is greyed out, so I cannot set the dependency for this variable.
The first variable is an input feature layer and the second is a list of fields from that feature layer. Documentation (https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/modelbuilder/model-parameters.h...) states this functionality exists; however, I cannot seem to achieve this on a model.  It works fine with a script though.
While researching this issue I came across a previous post on this topic, but it there was no resolution on the post. https://community.esri.com/t5/arcgis-pro-questions/parameter-dependency-non-functional-in-arcpro/td-...
Any assistance with this would be appreciated!
DanPatterson
MVP Esteemed Contributor
The list of fields from the feature layer would be a "derived" parameter
Model parameters—ArcGIS Pro | Documentation
... sort of retired...
KristieReece
New Contributor III
The documentation states that derived parameters by default become an output. The parameter I am trying to set needs to be an input. Once the user selects the desired feature layer they need to specify the field within the layer to be used on when the tool runs.
DanPatterson
that leaves "Dependency" in the link
