ArcGIS Pro - Is it capable of doing a street intersection list like in this blog?
1699
6
06-04-2024 05:39 PM
LukeAllen1
Hi all,
Wondering if any Pro users can help me here.
I am currently not using Pro but will soon be transitioning.
A big part of my workflow in ArcMap is creating a street intersection list. Historically I have followed this blog to the letter and it has worked great.
https://www.esri.com/arcgis-blog/products/arcgis-desktop/analytics/more-adventures-in-overlay-creati...
Do you know if I can reproduce this same workflow in ArcGIS Pro?
I didn't know specifically whether it was possible to do the following part of the blog, I didn't see much on it in the ArcGIS Pro spatial join tool documentation;
https://downloads.esri.com/Blogs/analysis/IntersectionList/FieldMapSteps.png
Thanks for any input!
Luke
IssyAmis
Hi @LukeAllen1
Thanks for your question - this is definitely possible in ArcGIS Pro.
It's a similar workflow, it will just look slightly different than what you see in that blog. The following blog should provide you with the steps for the first half of the workflow: How To: Create Points on Line Intersections in ArcGIS Pro (esri.com)
Then you should be able to do a spatial join as the ArcMap documentation mentions - just instead of having the "Merge rule" settings, you'll just select "Concatenate" for your new field and choose what delimiter you'd like to separate the input values. You'll also want to select the street name field to sort out the field mapping on this page. Hopefully, this screenshot of my settings should help you (I've used that "Add Empty Field" option to add in the "Name" field):
Happy to explain anything in further detail if needed!
Issy
IssyAmis
Hi @LukeAllen1
Issy
LukeAllen1
Thank you Issy! I'm, hoping to get ArcGIS Pro at home soon so will be playing around with it. Appreciate you taking the time to help!
Dale_Honeycutt
Hey all;
Using Intersect to create intersection points results in duplicate points at each intersection (just like Feature Vertices To Points does).  The output type is multipoint, not point.  So, you'd still need to delete the duplicate points and, possibly, convert the multipoint to points (unsure).
Ideally, the Feature Vertices To Points tool should have an option to output line endpoints without duplicates.  I submitted an Idea about this and if you get a chance, read it over and give it a Kudo.  I think the more Kudos an Idea gets, the more likely it will be implemented.
https://community.esri.com/t5/arcgis-pro-ideas/feature-vertices-to-points-option-to-remove/idi-p/141...
LukeAllen1
Thank you Dale I will definitely go and provide the Kudos! Also thank you for writing the original blog, its helped me in one of my work routines tremendously over the years 🙂
Dale_Honeycutt
Yea, that blog has had a long life! Glad its helped you.  And thanks to IssyAmis for updating how the Spatial Join dialog works in Pro (it's really a lot better/intuitive)
LukeAllen1
I was having a conversation with my work colleague earlier today about this topic. Did they update this blog or did I dream it? I feel like someone else posted an update of the street intersection, or maybe republishing Dale's blog after it went offline a few years back? Maybe I'm just getting old and imagined it.
