ArcGIS Pro crashing when I open any project after 2.7 update
4050
13
01-14-2021 09:34 AM
cartoranger47
Hello everyone,
Since upgrading to the 2.7 update last week, any time I try to open an existing project or open a new project in ArcGIS Pro, it crashes. I'm on Windows 10 with the latest updates installed. I haven't seen anything on here about this yet, so I'm wondering if anyone has any tips for common things that could be causing this like cache/profile files I could delete or something like that. I tried removing any extensions and that didn't fix the problem.
Alex
Tags (1)
DanPatterson
MVP Esteemed Contributor
Did you try  Windows  Add/Remove Programs, select Remove, then the Repair option?
I usually do a clean uninstall and install  when going from X.Y upgrades rather than upgrading through Pro
... sort of retired...
Katie_Clark
MVP Regular Contributor
I had issues with my original upgrade to 2.7 when I upgraded within ArcGIS Pro. @DanPatterson actually helped me with my post about this as well! When I removed the software and then did a fresh install with downloading 2.7 through myEsri, things are working fine.
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
VMitch
I had this happen also and a fresh new download did the trick 🙂
pt024
I uninstalled and reinstalled but the problem still persists. Can anyone advise on what to do?
DanPatterson
Did you rename the folder in c:\users\ you \local\Appdata\esri to ... esriOLD and you may also want to do the same using the registry editor regedit and rename Computer\HKEY_CURRENT_USER\SOFTWARE\Esri
in a similar fashion
pt024
I tried renaming the folders. The program still crashes when I try to open a project or template.
DanPatterson
you have to do that after you completely uninstall anything arc*.  Then reinstall.
If that doesn't work... Tech Support
pt024
It still crashing. I think I will have to contact support. Thanks for the help.
Colcam4
Have you resolved this?
I am having serious problems with the new ArcGIS Pro 2.7.2. Downloaded today.  I get  ENDLESS spinning/loading icons, whenever I try to use Tools. Something ain't right. Do I have to get ESRI to fix? Or IT to reload the software? Had to use Task Manager to End Task. Exited/Restarted 5+ times. Rebooted computer 2 times.
