ArcGIS Pro connect to snowflake verified but no tables showing
881
5
01-12-2024 03:40 AM
DanHardwick
I have successfully validated a database connection to a snowflake server, and I can see the different databases available, so I believe the connection properties are correct, but when I try open the connection via Catalog, no tables are returned.
I followed the below guidance:
https://pro.arcgis.com/en/pro-app/latest/help/data/databases/connect-snowflake.htm
Currently using: ArcGIS Pro version 3.2.0, Snowflake ODBC client 3.1.4
I also have the connection working in ArcGIS Online, so the issue I have is with ArcGIS Pro specifically. Any ideas please?
HCFCDGIS
I am experiencing the same issue, did you ever find a solution to this @DanHardwick ?
MadelineWhitted
I'm also experiencing this same issue.
dmorales
I, too, have successfully connected to Snowflake with ArcGIS Pro Database connection and created a query layer but no data was returned.   Also, I used python to connect to Snowflake and I was able to fetch data, create an in_memory table, and geocode. However, I'm only able to fetch 5000 records.  Script crashes ArcGIS Pro otherwise.   Didn't experience this issue when downloading data from Netezza.
RafaelGil
Hi @DanHardwick It sounds as though you are encountering a known defect: "BUG-000167251 : Beginning with ArcGIS Pro 3.2 Snowflake data is no longer listed under new database connections."  Please contact Esri Support  so you can subscribe to this defect; doing so can help us understand the demand behind this bug.
As a workaround, you can grant the connecting role the 'Select' privilege to any table with a shape field. If you do not have a table with a Shape field you can create a new table from your Snowflake console using the following SQL:
CREATE TABLE <SCHEMA_NAME>.SUPPORT.TestGEOG (id integer, shape GEOGRAPHY)
If you need assistance with the workaround, please feel free to message me directly 🙂.
DanHardwick
Thanks @rafa , I am not sure if that work around will work for me, as the tables we are working with don't contain Shape fields, and we only have a READER account into the snowflake environment which we connect to, so I don't think we will have permissions to create the Shape fields either.
That being said, I have successfully connected to the snowflake tables within the ArcGIS Pro data interoperability extension, so this has been a good workaround for me, and I just create the necessary outputs to then read into ArcGIS Pro. Appreciate this won't be an option for everyone though, but may help @dmorales  @MadelineWhitted  @HCFCDGIS
