ArcGIS Pro Concurrent licensing retiring
22588
27
02-14-2024 03:40 AM
GISWT
We are hoping to expand the usage and licenses of ArcGIS Pro within our organisation but have been told that we cannot purchase Concurrent licenses as they are being depreciated and our only option is named user. We are a small organisation with only 2 core GIS users and many adhoc users, when they need to use ArcGIS it is for short-term projects and tasks, often with quick turnaround. It is not viable for us to buy licenses for all of these users but having to manually assign licenses as and when a user needs one also creates a major blocker for us in the system (what if the admins are unavailable, which is highly likely).
Has anyone else come up against this issue and been forced down the named user path? How are you managing the situation? I can't find any documentation or Esri communication about this change and can imagine many more companies will have similar difficulties. The only thing I can find is it almost happened in 2016 but in 2017 Esri back tracked because of user discontent.
SheriNorton
We're just over the Small Gov ELA (only time great demographic trends are a bummer), so that's not a feasible path. We'll spend the next 11 months really looking at our users needs and try to eval whether to downgrade (or simply eliminate) licenses. This would have been somewhat easier to stomach and fund if the increases had been gradual the past 10-12 years, rather than such an enormous jump at once.
ZachBodenner
MVP Regular Contributor
ESRI has been trying to nudge organizations in this direction for a while now. Up until a few years ago they let you convert concurrent licenses to named users a little bit cheaper but that's no longer offered. It's a pretty disappointing that their stance has always been that concurrent licenses aren't going away if you already have them, only to finally pull the plug without a ton of warning. Their stance is that the simplified user roles mean that products that used to require additional licensure no longer do, but the fact is that the new user roles are so expensive that most of the time it doesn't matter.
Happy mapping,
- Zach
MarkChilcott
Hi David
How did it work out?  I am about to go through the same thing.
Cheers,
Mark
MarkChilcott
Hi Sheri,
Cheers,
Mark
vnixon
I unfortunately only learned about this imminent deprecation from a Reddit post 2-3 months ago. My plan is to convert as many of our desktop workflows to web gis as possible to reduce the impact of the price increase. I work in a State agency with almost 200 ArcGIS Pro users, 100% on concurrent use licenses. Usage ranges from occasional basic data exploration that may be replaceable with web applications to full-time advanced analysis and development that will continue to require ArcGIS Pro. Luckily we do not need to purchase new licenses this year but we are in a very tight budget year, short-staffed on our central GIS team, and very worried about the following:
  •     An estimated tripling of our bill if we were to simply convert our concurrent license users to named licenses
  •    The time needed to research potentially dozens of GIS workflows, develop replacement web applications, and train users
  •     Feeling like a frog in slowly boiling water and not knowing how quickly the cost of maintaining our concurrent use licenses will increase and when exactly they will be deprecated
Bud
Legendary Contributor
This isn't my area of expertise, but are you able to push back and insist that you be grandfathered in since you already have concurrent licensing?
ZachBodenner
During conversations with my account manager, I didn't exactly push back, but I did not get the impression it was an option to avoid the new user model.
Happy mapping,
- Zach
LindsayRaabe_FPCWA
Always ask the question - we've had a few scenarios where things were "not possible" that later have seemed to indeed be possible (with some wrangling).
Lindsay Raabe
GIS Officer
Forest Products Commission WA
MarkChilcott
Hi vnixon,
Your organization has similar set up to ours.  About to re-negotiate ELA.  This will be the my 6th one.  How did it work out for you?
Mark
SimonSchütte_ct
@vnixon "not knowing how quickly the cost of maintaining our concurrent use licenses will increase and when exactly they will be deprecated"
The concurrent use license model is directly linked to ArcMap. It was never possible to buy ArcGIS Pro concurrent use licenses. They were part of the ArcMap license to help the transition to ArcGIS Pro.
If you have perpetual licenses for ArcMap, you can keep using the accompanying ArcGIS Pro license as well. With the End of Life of ArcMap in 2026, maintanance will also end. Therefore, you can continue using the Software in the last version that will be released in 2026. (To my knowledge)
If you want to use the latest ArcGIS Pro version after the end of life date of ArcMap, you need to switch to named user based licenses managed in ArcGIS Online or Enterprise (based on the information available at this point in time). I for example did not hear anything about an maintanance increase for 2025+ or that it even is an option to continue maintanance for concurrent use licenses beyond 2026, but maybe this is region/industry specific. Best discuss the migration strategy with your account manager.
"With the upcoming retirement of ArcGIS Desktop, the ArcGIS named user model will be the only method for licensing ArcGIS. The ArcGIS Pro licensing methods that we knew until now, such as Single Use and Concurrent Use, will be deprecated."
Information source: Esri Spain
