ArcGIS Pro can't find an Excel worksheet, freezes/hangs
1533
10-18-2022 02:04 PM
Matt-Goodman
I quickly found a workaround, but am so frustrated with the fact that ArcGIS Pro can't seem to to 'see' an Excel worksheet through the "Add Data" dialog. When I click into the workbook (xlsx), the dialog just spins and spins and spins....then canceling or closing down the application often requires an "End Task" in the Task Manager.
Things I've tried:
- check the Excel workbook for correct formatting (there are only two simple columns, both named with text names and containing simple integers).
- tried both .xlsx and .xls
- tried moving the Excel file to a different location in the directory
- tried updating ArcGIS Pro 3 to the latest patch (3.0.2).
- tried rebooting the computer
- while Pro was spinning its wheels, I launched ArcMap (10.7) and added the Excel worksheet without issue
Anyone else experiencing this?
Attached: .xlsx file
Tags (3)
Robert_LeClair
Esri Esteemed Contributor
Matt - I'm working with ArcGIS Pro 3.0.2 and had no problems loading your Excel file using the Add Data button or via the Catalog Pane.  I'm wondering if you have the necessary drivers for Excel to work properly in ArcGIS Pro?
Matt-Goodman
I've confirmed:
  • Running Office 365, v.2209, click-to-run, 32-bit
  • have MS Access db engine 2016, 32-bit, silently installed
  • have .NET Desktop runtime 6.0.5.31215 x86, silently installed
The weird thing is, I've been on ArcGIS Pro 3.x since July (3 months now) and haven't had any issues with Excel tables until the last week or so.
Robert_LeClair
Matt - I think the problem is you're running the MS Access DB engine 2016, 32-bit versus the 64-bit driver.  You can learn more about this and other Excel solutions here.
LuisLaredo
Hello,
I agree with Robert above.  Pro would use the 64bit version of Access DB engine.  When we've 'packaged' ArcGIS apps for our organisation, we've had to include both versions for Pro and Desktop users.  Since Microsoft 365 came about, it became a bit of a problem because of compatibility with the Standard Operating Environment.
Having said all this, in our testing, we have seen cases where people in our team, with seemingly identical setups, would be successful and not when trying to open an Excel file in ArcGIS Pro.  So in the next version, we'll be including both 32bit and 64bit versions of ADE and save ourselves the trouble.
. Luis
