ArcGIS Pro 3.1.5: Why does a tool added to the model builder canvas appear inverted?
In the screenshot below, the "calculate field" tool is added, but it appears inverted. How can I make it appear by default as shown in the second screenshot?
@JamalNUMAN Looks like it's drawing per some default layout rules. You can also manually adjust the tools per your needs. In this case, dragging up the Calculate Field element will do the trick.
There is no such layout rule that controls this behavior
This issue has previously been discussed here:
https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-2-5-how-to-get-the-added-tool-to-the/t...
idea suggested here:
