ArcGIS Pro 3.1.2 Train Deep Learning Model Error 032659
3380
07-22-2023 04:26 PM
collinweise
I have been trying to train a deep learning model, but when I add the training data I get this error code:
Error 032659 updateParameters Error: Traceback (most recent call last):
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.validate.py", line 736, in <module>
File "c:\program files\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.validate.py", line 273, in updateParameters
import arcgis.learn
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\__init__.py", line 7, in <module>
from arcgis import features
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\features\__init__.py", line 26, in <module>
from .feature import Feature, FeatureSet, FeatureCollection
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\features\feature.py", line 22, in <module>
from arcgis.geometry import (
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\geometry\__init__.py", line 82, in <module>
from .functions import *
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\geometry\functions.py", line 18, in <module>
from arcgis.gis import GIS
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\gis\__init__.py", line 44, in <module>
from cachetools import cached, TTLCache
ModuleNotFoundError: No module named 'cachetools'
I've tried unistalling both ArcGIS Pro and the deep learning libraries for 3.1 with no change.
Thanks for yalls help!
Tags (1)
DanPatterson
MVP Esteemed Contributor
check you installation for the cachetools module
Solved: ArcGIS Pro Notebook error - Esri Community
No module named 'cachetools' · Issue #36 · Esri/deep-learning-frameworks (github.com)
it could be an install or version issue
... sort of retired...
DanPatterson
collinweise
A full reinstall of ArcGIS Pro and the Deep Learning Libraries did the trick. I had to be sure to get rid of all other install packets first, which may have been the original issue as to why my other reinstalls didn't work.
Thanks for your help!
