ArcGIS Pro 3.0.2: The legend fails to respect the number of decimal places as per the expression set for a field,
In the screenshot below, the expression below is set for the indicated field
Round($feature.sumPlnP_lnK, 2)
Nevertheless, the number appears in the legend doesn’t respect this expression as I expect to have the numbers with only two decimal places.
What could be the issue here?
In my case, the way to solve it was always changing the values of the legend manually.
I don't know if there is a way to change the values automatically.
Try using Advanced symbology options:
Thank you BarryNorthey for the help. It works fine as per the screenshots below
