ArcGIS Pro 3.0.2: The legend fails to respect the number of decimal places as per the expression set for a field,
981
07-05-2023 01:44 AM
JamalNUMAN
Legendary Contributor
In the screenshot below, the expression below is set for the indicated field
Round($feature.sumPlnP_lnK, 2)
Nevertheless, the number appears in the legend doesn’t respect this expression as I expect to have the numbers with only two decimal places.
What could be the issue here?
Jamal Numan
BarryNorthey
Occasional Contributor III
Try using Advanced symbology options:
JeremíasAcosta
Hello,
In my case, the way to solve it was always changing the values ​​of the legend manually.
I don't know if there is a way to change the values ​​automatically.
BarryNorthey
JamalNUMAN
Thank you BarryNorthey for the help. It works fine as per the screenshots below
Jamal Numan
