ArcGIS Pro 3.0.2: The ArcGIS Pro catalogue fails to detect the Revit file of *.rte format,
I couldn’t figure out how the Revit file of *.rte format can be inserted to Pro. It appears that the catalogue of The ArcGIS Pro is not able to recognize this format.
What could be the issue here?
Solved! Go to Solution.
Which exact version of ArcGIS Pro works with Revit 2023?
From the 3.1 help files
Supported BIM geometry—ArcGIS Pro | Documentation
ArcGIS Pro supports Revit file versions 2018–2023
The 3.0 help doesn't mention anything, ergo....
