Is it possible to create a voxel model from a multipatch volume?
1598
01-07-2023 08:30 AM
David_Brooks
MVP Regular Contributor
I have a collection of multipatch volumes that represent a ground model, and Im wandering if it's possible to convert these into a voxel dataset?
The volumes were created by extruding between 2 TIN layers (isosurface and isobase rasters converted to TIN) in order to generate the volume of each soil type.
However, the end product would be much better as a voxel model. Any ideas braintrust?
David
..Maps with no limits..
JordanV
Hi David - did you ever find a solution to this one? I’ve found myself in the exact same situation.
Marc_Graham
Hi @David_Brooks  and @JordanV
Did either of you come up with a workflow for this? I too would like to convert a ground model multipatch to voxels.
Marc
