ArcGIS Pro 3.0.1: How to measure the time for performing a particular tool in the model builder?
2440
13
09-01-2022 09:59 PM
JamalNUMAN
Legendary Contributor
For example, the model below is intended to query an indexed and a nonindexed layer. I wanted to compare the time between these two cases. This is why I need a tool to measure the time to perform the “select by attribute” in these two cases.
Jamal Numan
DanPatterson
MVP Esteemed Contributor
Timing is best done in python.  It needs to be scripted with calls to collect time information and the actual tool being used.
For instance the code samples for a tool show the required syntax to perform a select by attribute
Select Layer By Attribute (Data Management)—ArcGIS Pro | Documentation
to collect time you throw what you need between the time collecting code
performance - How do I measure elapsed time in Python? - Stack Overflow
provides a simple example of the concept
import time
start = time.time()
# -- amazing things section
print("Replace this with the select by attributes code")
# -- now find out how long it took
end = time.time()
print(end - start)
... sort of retired...
JamalNUMAN
I exported the model into a python but couldn’t figure out how to stick the piece of code you have already provided in order to get the time printed.
Could you please help me on this?
# -*- coding: utf-8 -*-
Generated by ArcGIS ModelBuilder on : 2022-09-02 12:37:39
import arcpy
def Model():  # IndexingElapsedTime
    # To allow overwriting outputs change overwriteOutput option to True.
    arcpy.env.overwriteOutput = False
    # Model Environment settings
    with arcpy.EnvManager(scratchWorkspace=r"C:\Z8\Q.gdb", workspace=r"C:\Z8\Parcels_NonIndexed.gdb"):
        Parcels = "Parcels"
        # Process: Copy Features (Copy Features) (management)
        Output_Feature_Class = "C:\\Z8\\Q.gdb\\Parcels_CopyFeatures"
        arcpy.management.CopyFeatures(in_features=Parcels, out_feature_class=Output_Feature_Class, config_keyword="", spatial_grid_1=None, spatial_grid_2=None, spatial_grid_3=None)
        # Process: Add Attribute Index (Add Attribute Index) (management)
        Parcels_CopyFeatures = arcpy.management.AddIndex(in_table=Output_Feature_Class, fields=["ParcelNumber"], index_name="ParcelNumber", unique="NON_UNIQUE", ascending="NON_ASCENDING")[0]
        # Process: Select Layer By Attribute (Select Layer By Attribute) (management)
        Parcels_CopyFeatures_Layer, Count = arcpy.management.SelectLayerByAttribute(in_layer_or_view=Parcels_CopyFeatures, selection_type="NEW_SELECTION", where_clause="ParcelNumber = '72'", invert_where_clause="")
        # Process: Copy Features (2) (Copy Features) (management)
        Output_Feature_Class_2_ = "C:\\Z8\\Q.gdb\\Parcels_CopyFeatures1"
        arcpy.management.CopyFeatures(in_features=Parcels, out_feature_class=Output_Feature_Class_2_, config_keyword="", spatial_grid_1=None, spatial_grid_2=None, spatial_grid_3=None)
        # Process: Select Layer By Attribute (2) (Select Layer By Attribute) (management)
        Parcels_CopyFeatures1_Layer, Count_2_ = arcpy.management.SelectLayerByAttribute(in_layer_or_view=Output_Feature_Class_2_, selection_type="NEW_SELECTION", where_clause="ParcelNumber = '72'", invert_where_clause="")
if __name__ == '__main__':
    Model()
Jamal Numan
JakeSkinner
Esri Esteemed Contributor
Hi @JamalNUMAN,
Try the following:
import arcpy, time
        Parcels = "Parcels"
		startTime = time.time()
		endTime = time.time()
		elapsedTime = endTime - startTime
		arcpy.AddMessageE(f"Selection took {elapsedTime} seconds to complete")
    Model()
JamalNUMAN
It fails to run. I got an error
Jamal Numan
JakeSkinner
Make sure the indentation matches for the highlighted lines.  They should align with the same indentation as the Parcels_CopyFeatures1_Layer,.... line.
JamalNUMAN
I got an error as per the screenshot below
import arcpy, time
    arcpy.env.overwriteOutput = True
        Parcels = "Parcels"
    Model()
Jamal Numan
JakeSkinner
Type-o on my part.  Just remove the extra E in arcpy.AddMessageE (line 28 and 29).  Should be:
arcpy.AddMessage(f"Selection took {elapsedTime} seconds to complete")
JamalNUMAN
It works fine but the elapsed time is not printed for the “select by attribute” tool
import arcpy, time
        Parcels = "Parcels"
    Model()
Jamal Numan
JakeSkinner
How are you running the script?  You may need to change arcpy.AddMessage to print.
