ArcGIS Pro 2.9.1 Patch installs ArcGIS Pro Intelligence
1827
02-07-2022 05:11 PM
Aaron-L
We silently deploy ArcGIS Pro 2.9 to end user desktops. We specifically have the silent install setup to not include ArcGIS Pro Intelligence (ADDLOCAL=Pro). We have found when deploying the ArcGIS 2.9 Pro Patch 1 (2.9.1), that after the install, the ArcGIS Pro Intelligence icons now show up in the Start Menu. I have tried running the patch both silently, or just standard through the GUI, they both add the icons to the Start Menu that weren't there previously. Is there a way to keep the patch from adding ArcGIS Pro Intelligence icons? ADDLOCAL=Pro did not work on the patch.
Robert_LeClair
Esri Esteemed Contributor
This seems to be "BUG-000134833 - Silent install of ArcGIS Pro 2.6 Patch 2 incorrectly defaults to ADDLOCAL=ALL" and installs ArcGIS Pro Intelligence.  Not showing when the bug will be fixed but you can contact Esri Support Services to add your customer number to the bug report.
Robert_LeClair
Aaron-L
Thanks for the info! Doesn't look it's going to be fixed any time soon since that bug was logged for ArcGIS Pro 2.6 and we are on 2.9 now. At least I know it wasn't something I was doing wrong in the deployment.
Robert_LeClair
Nope - I'd say you're doing everything correctly and it's a bug.  If you feel my answer was correct, you can close thread by marking the answer correct.
