ArcGIS Pro 2.7: Which to tool can intersect layers but to keep all non-intersecting features?
2667
02-03-2021 03:57 AM
JamalNUMAN
Legendary Contributor
For example, in the screenshot below, the intersection between L1 and L2 is two features. How to keep the non-intersected features so that the outputs ends up with 9 features but not with 2!
I’m aware that I can perform multiple tools to achieve that but wanted to check if there is one single tool that can do the job
Jamal Numan
ThomasThorsen1
Try the union tool
ThomasThorsen1
Try the union tool
JamalNUMAN
Thank you ThomasThorsen1
Not sure why i thought that the union tool will duplicate the area of interesection! It works fine
Jamal Numan
DanPatterson
MVP Esteemed Contributor
How Union works—ArcGIS Pro | Documentation
because
Below is an example of Union with features within a feature class that overlap. In this case, the area of overlap will be duplicated to maintain all the attributes and areas.
... sort of retired...
DanPatterson
Select by location... once you get the selection, just switch the location in the table
