Arcgis Pro 2.7 does not load Raster Files
1989
12-26-2020 09:08 AM
by Anonymous User
Not applicable
I bought a new computer, with 16 GB of memory, Geforce RTX 2060 video card, to work with ARCGIS pro 2.7, for which I have a one-year subscription. I installed the program but when I want to work with RASTER files the program gives an error message. In the attached file I put a print screen of the error message I receive. How can I solve this problem?
DavidPike
MVP Notable Contributor
what format is the raster in e.g. (.tif, .asc, within an FGDB)? does it have the correct extension in the filename etc.? Can't really see the root cause from that just error message.
DanPatterson
supported raster formats
Raster file formats—ArcGIS Pro | Documentation
supported by the Image Analyst
List of supported sensors—ArcGIS Pro | Documentation
Then there are others for netCDF, voxels and other things.
If you can narrow down the source of your data, it may simplify what is needed to read the file
... sort of retired...
Robert_LeClair
Esri Esteemed Contributor
If the native raster is in an unsupported format, you can use the Data Interoperability extension to import it into a format that ArcGIS can understand.  You can learn more about the tool here.
