ArcGIS Pro 2.6: Publishing fails to cache at all scales,
1020
08-11-2020 09:34 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why publishing fails to cache at all scales.
In the screenshots below, I wanted to catch a mosaic at 14 scales (from L00 to L13). I observed that it stops at L08 despite the fact that it says “succeeded”
What could be the issue here?
Jamal Numan
MajdoleenO_A__Awadallah
Please try to create a new schema, it seems that their is an error in the schema. I found out that this error is general and their is a problem with Arcgis pro when it comesschema.
Best
Majdoleen
JamalNUMAN
Thanks Majdoleen.
Correct. I tried to re-create the scale tiling scheme and it worked fine. I’m attaching the two files: the one that fails to work and the working one!
What could be the issue here? Both of them are created by the tool and the content is never touched
Is this a bug?
Jamal Numan
George_Thompson
Esri Notable Contributor
Did you have the cache to be automatically created on the server or manually?
You may want to look at the server CachingTools service. You may need to kick off the process again. I usually publish the service, then start the caching process on the server.
--- George T.
JamalNUMAN
Thanks George.
It is cached automatically is the server.
But how it works fine as the scale tiling scheme is regenerated? What’s wrong with the first one? Both are created with the same tool
As you know, there is no proper environment equivalent to the one of ArcMap to better manage and monitor caching
Jamal Numan
