ArcGIS Pro 2.6.3 Scheduler: Schedule a tool to run after another tool successfully runs
2799
12-09-2020 11:14 AM
RossCBrewer
Using ArcGIS Pro 2.6.3's scheduler functionality, is it possible to schedule one tool to run immediately after a different tool successfully finishes?
*I'd prefer not to schedule these tools by time (seemingly the only option) because tool1 can take anywhere from 1 to 2 hours, and tool2 is deleting duplicate records from tool1, which could result in inaccurate data during the gap between the tools.
RobertKacir
My recommended solution would be to create a model with both tools in it specifying the execution order. You can then schedule a single model instead of a two different tools. In model builder if the first tool fails, the second tool will not execute.
RobertKacir
BenCoubrough
Hi @RossCBrewer I'd also recommend what Robert has suggested by using the ModelBuilder.
If you haven't built a model before you can follow this great tutorial which shows you how to build a geoprocessing model to automate a workflow.
Make a geoprocessing model - https://pro.arcgis.com/en/pro-app/get-started/make-a-geoprocessing-model.htm
Schedule a model - https://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/modelbuilder/scheduling-a-model-run.ht...
Schedule geoprocessing tools - https://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/basics/schedule-geoprocessing-tools.ht...
